archaic precast gypsum plank roof deck
I am trying to determine the fire rating and uniform load capacity of an old roof deck system called Pyrobar. Need to replace damaged portion of it on a flat roof of an old building. The roof deck consists of a flat deck of 3" solid Gypsum planks 1' wide and 3' long supported by doubled light gage channels, in turn supported by structural steel framing. The planks are not poured on site but precast. There is a hung ceiling below which may be part of the assembly. The building may date from the late 1930's. Google has not been of much help. Any insight or experience appreciated.
RE: archaic precast gypsum plank roof deck
Mike McCann, PE, SE (WA)
http://www.structurearchives.org/article.aspx?arti...
Maine EIT, Civil/Structural.
Mike...good links...thanks.
https://archive.org/details/PyrobarGypsumTile
On the left side of the webpage you can download a .pdf version (free).
www.SlideRuleEra.net
www.VacuumTubeEra.net
