question about master model
I am doing my drawings on my current job using the master model approach
We reuse a lot of out designs by cloning them to a different job number and editing them, the one I'm doing now is close to 1000 components
Once I get all my drawings done i will have a pile of drawing files that are not linked to the main assembly
now when I do my clone of my main assembly, how to I get the drawings over so I don't have to re create them
Brian Marchand-Die Designer
http://www.armotool.com/
NX 9.0.2.5 / PDW
Dell Precision T7610 w/Xeon ES-2609
16G Ram - Nvidia Quadro K5000
Win 7 Pro x64
RE: question about master model
If I understand this correctly I think you need to do the clone of the main assembly first, instead of last.
Hi Brian,
You could create an extra assembly file.
By drag and drop you can add all your drawing files into this one.
When you Clone your main assembly, add the assy file containing all your drawing files as well.
Best regards,
PascalDW's solution will work
NX 9.0.2.5 / PDW
Win 7 Pro x64
