Removing Floor Reflection in RealView
I have searched and cannot find an option for removing the reflection off the floor when using RealView graphics. PhotoView does not give me the results that I want, but RealView does except for the reflection.
I have tried distancing my assembly well above the floor, but that did not work. I made a white floor board and adjusted its illumination so that it a) appeared white, and b) had no reflection. This actually worked, except I need a very strong perspective view (factor ~ .25). With this perspective view the floor took on a shading gradation of its own.
I think the best results would be to turn off the floor reflection in RealView. Does anyone know the trick for that? I could not find it in SWX Help.
Many thanks in advance!
- - -Updraft
- - -Updraft
RE: Removing Floor Reflection in RealView
Jeff Mirisola, CSWE
My Blog
That was perfect! Thanks and a star for you!
- - -Updraft
Jeff Mirisola, CSWE
My Blog
