Problem with visualisation of Patran results
Hi
I am new to Nastran/Patran and recently installed version 2013 and tried to run a simple thermal analysis. Everything goes fine but after I attach the .xdb file and try to plot the results there is nothing to select in the "select result cases' , "select fringe result", and "select deformation result" fields. The .f06 file looks fine (no error messages and temperature vector is calculated). Any thoughts?
Thank you!
Thank you!
RE: Problem with visualisation of Patran results
What are the outputs requested?
