clone problem
clone problem
clone problem
I must be doing something wrong with the cloning, i didn't notice this in 8.5
When I add an assembly to clone, I go to the naming tab and set replace, say with my old job number, and replace with, my new job number
Now I go back to my main tab and click exceptions because there are usually a few parts that I did not add job number to like the customer part file etc
Everything is set to default and the default action is to clone
I used to highlight the files I want to change, and with the pull down set to retain, I click apply and those highlighted files would change to retain and all would be good
Now when I hit apply it changes 80 percent of the files to retain, not just the ones highlighted
An I doing something wrong here
Brian Marchand-Die Designer
http://www.armotool.com/
NX 9.0.2.5 / PDW
Dell Precision T7610 w/Xeon ES-2609
16G Ram - Nvidia Quadro K5000
Win 7 Pro x64
