Uniaxial/triaxial compression: cylinder rotation
I've been working on this problem for quite a while now. I'm trying to simulate triaxial compression of a drained clay sample. I cannot use an axisymetric model because i have layers at odd angles that i will add different material properties to once i get the elastic, homogeneous solution correct, therefore i have to use a 3d model.
My problem is that my cylinder rotates when a confining pressure or displacement is applied. Is this a common problem? The only way I have found to keep the cylinder from rotating is by adding friction between the clay cylinder and the rigid end caps/platens. However, i need 0 friction to minimize the error for the elastic solution. I have tried many different things to fix this: surface-to-surface contact versus node-to-surface, small sliding vs finite, refined mesh, different mesh type (hybrid), nlgeom. If you look at my images closely you can see how the elements have rotated. What am i forgetting? Thanks
RE: Uniaxial/triaxial compression: cylinder rotation
Rob Stupplebeen
www.optimaldevice.com
