Access fittings are Branches under API 1104?
dear all,
We have these Cosasco Nipples, used for inhibitor injection o corrosion monitoring (http://www.cosasco.com/documents/50_Flarweld_Acces...). For in service welding of this fittings under Apendix B of API 1104, should the WPS be for Branch joints?
thanks in advance.
Octavio Chable.
RE: Access fittings are Branches under API 1104?
Yes - this is a branch connection; it attaches to the main pipe header/line, it is many sizes smaller than the main line.
According to App B of API 1104, for in-service welding (B.2) procedure qualification for fillet weld in Sect. 5 should be applied.
Also specified in B.2.3 "The requirements in 5.7 for branch and sleeve welds are appropriate for in-service welding".
(Note: 5.7 specify qualification for fillet weld).
regards,
AR
The fitting/device that is shown on your link welds on very similarly to an O'let; there is supposed to be full-penetration of the root. This makes it a small-bore butt weld. And yes, a procedure or welder only qualified for big-bore buttwelds is not qualified to work on small-bore.
