Automatic Inflation Mechanism
I am trying to design a system with a sensor that can detect when an inflatable is inflated to 2 PSI. I am trying to inflate something small, around 6 liters. I currently have a system that uses a solenoid, the compressed air, and a mechanical timed relay that tells the system when to stop inflating. The issue is that i want to make it using a sensor or gauge to tell the system to stop inflating at exactly 2 PSI.
Please let me know if you can help. All questions, comments, or suggestions are welcome.
RE: Automatic Inflation Mechanism
A.
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
Personally, I would use the approach others suggested, using a mechanical relief valve to control the inflation pressure. This is the most fool-proof and reliable approach.
