Lock cell reference to cell, not contents
This seems like it should be simple but maybe it's bed time!
In cell A1 is the formula =B1. Easy enough.
What I would like is for A1 to reference B1 exclusively. In other words "Do not follow the content of B1 around the
sheet when I move it. Is this even possible?
Doug
Doug
RE: Lock cell reference to cell, not contents
Try:
CODE
that are copied from the original.(A1) Regardless of what I've tried, if I move the source cell contents the
home cell retains (follows) the source cells contents. Is there a setting to change what the home cell
references?
A1 formula....=B1
Type 1 into B1
Highlight and grab outside of B1 and move it to C1
Highlight A1
Formula now reads =C1
A1 formula should still read =B1
Doug
-handleman, CSWP (The new, easy test)
I'm not on a PC, so I can't check the syntax.
I changed ("B1") to ("B:B"), dragged copies down so that it works in a list.
You are the man!
Doug
I tried offset but it looks like it follows the source as the source moves.
Thanks for the reply tho.
Doug
Also, if you want to move a value, but still leave formulas unchanged, you can copy and paste, then delete the original, rather than move.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
I'm using the indirect function. The problem is that I need to reference different portions of a list (About 200 rows long). I need to fit the output to paper so I'd like to reference 50 of the rows in the list at a time placing them side by side.
Cells A1 thru A50 reference the first 50 entries in the list.
Cells D1 thru D50 reference the next 50
I tried using named ranges but to no avail. Any thoughts on the proper way to do this?
Doug
