Cosmetic Chamfer
Cosmetic Chamfer
Hi Y'all,
How would you create a chamfer / flat 0.75 mm across, normal to multiple surfaces? I've used every combination of the chamfer command I can think of and it's not quite the results I'm looking for. I tried offsetting curves in faces without success.
In the attached model the green body would have this feature similar to the red body.
Any assistance will be most appreciated!
~Felicia H.
NX 8.5.3.3
