Coating/Lining of Drain Pit
Our client has a pit with HCL, NaOH, NAOCL, FeCl3 coming from different lines in different proportions in a concrete tank.
Which type (coating or lining or composite) and material of protection should be provided to prevent the concrete surface. Similar damage has occurred in an already existing pit with similar chemicals.
RE: Coating/Lining of Drain Pit
Look for ones suitable for use with the HCl.
There are some multilayer epoxy systems that might be suitable for this service.
Plymouth Tube
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
Steve Jones
http://www.atlasmin.com/products/corrosion_resista...
Do you know what the concentrations of chemicals listed are? Belzona supply epoxy linings which are used frequently for protection of primary and secondary containment areas against such chemicals. If you can provide some more information or drop me an email we can help out; kflanagan@belzona.com
