NX 9 Operating System and Hardware requriements??
Please let me know what is system configuration ( Hardware and Operating system) requried for NX 9 and above .
Thanks.
RE: NX 9 Operating System and Hardware requriements??
Hi sudhirnhuilgol,
If you are running CAD only, then generally 2 to 4 Gb RAM and 1 to 2 Gb graphic card will be fine. I always prefer NVidia Quadro if within budget. Window 7 64bit is good. Please take note that NX9 only available in 64bit.
You can find out more at
https://support.industrysoftware.automation.siemen...
for hardware and software (OS) Certifications.
Hi Mr Tuw,
Thanks for providing support on my query .
My observation :
I have 12GB of RAM in my system with OS of Win 7 & 64bit , but when i perform any operation like geometry change or do some logical calculation with in NX on huge Templates / CAD .
To give results/output will take more time . Which is bothering my work .
Could you please suggest some best practice or settings to be made in our NX session which can improve the performance of the Application also the system ?
Thanks in advance ,
Sudhir
Hi Sudhir,
May I know what is your current graphic card?
The CPU chip and its speed will also have an impact on performance, but most likely it is a graphics issue.
Also, what version of Windows7 doe you have? It comes in different levels and only the higher levels are supported.
Ben Loosli
