MAP
MAP
I'm a trainee engineer and am reviewing calculations of a pressure vessel done on COMPRESS. I have 2 questions regarding MAP.
1)I've noticed that when they calculate MAP for the bottom head, the formula is : P = 2*S*E*t / (K*D + 0.2*t) - Ps. The Ps calculated is 3.43 psi. Yet in the calculations for MAP they have taken the value of Ps as 0. Please explain.
2)Secondly, when i was going through the calculations for the cylindrical shell, they have not subtracted the static head at all. The formula used is : P = S*E*t / (R + 0.60*t). Why is Ps subtracted in the formula for the the bottom & top head but not
in the cylindrical shell??
RE: MAP
