Thin Walled Sandwich Cylinder
Hello!
I am having problems with a thin-walled sandwich cylinder.  First, the face sheets are made from 7075-T73.  The outer face has a radius of 400mm and a wall thickness of 0.406mm.  The core is made from ROHACELL (a strutural foam) and has a thickness of 7mm.  The inner face is again 7075-T73 aluminium, with a thickness of 0.406mm.
The struture is subjected to high axial compressive loads and a large bending moment.
What element type should I use?
Thanks!
RE: Thin Walled Sandwich Cylinder
shell99 or solid45
