OAPI SAP 2000 - Matlab
Hi, I've been using the OAPI functions with Matlab in order to extract some analysis results from a computational model with shells, but now I'm having troubles with some functions. I have a cellstring with the names of the areas assigned to a section cut, then, when I try to get the Section Property name with the function GetProperty, Matlab shows this message:
No method 'GetProperty' with matching signature found for class
'Interface.SAP2000V16._cAreaObj'.
I don't know what's wrong with my code:
Name = AreaNames{1,1};
PropName = cellstr(' ');
[ret,Name,PropName]=SapObject.SapModel.AreaObj.GetProperty(Name,PropName);
Thanks for your help!
RE: OAPI SAP 2000 - Matlab
It seems "AreaNames" is an existing array containing "Objects Name" from a previos Get function
I'd suggest you to create a for loop to get the "PropName" for each item in the AreaNames array and store the output in a new variable if you want.
the code could be something like this:
for i = 1:lenght(AreaNames)
[ret, PropName] = SapObject.SapModel.AreaObj.GetProperty(num2str(AreaName(i,1)),PropName);
end
you can remove the "Name" item next to the "ret" sentence since you already know the Name of the Area and thus is not a required output
