Using motion simulator for a reversing gear? (Unsure of the name, video inside)
I am trying to replicate the motion shown in this system: Reversing direction under constant input
I have no real purpose for it other than to show some interns how motion simulation works.
Is there a way to define this type of motion in NX? I have only been able to get the output gear to rotate one way or the other. Other than that I just get errors.
I am new to motion simulation myself so go easy on me please
RE: Using motion simulator for a reversing gear? (Unsure of the name, video inside)
The only two possibilities I can think of are to skip this portion of the mechanism, and use a Recurdyn formula function to drive a revolute joint that goes clockwise/anticlockwise at the correct intervals.
The other is to do a full 3D contact between fully-modelled gears, so that the teeth actually create the motion you are after. While this is possible, I would not recommend it due to how complex the solution would be, and the accuracy based on the degree of tolerance that always exists in using the contact tools in Motion Simulation.
Chris Abbott
TEAM Engineering
www.team-eng.com
