High strength core with hard surface
Hello, This is my first post to the site,I have googled many problems and this site seems to pop up quite a bit. I figured I'd give it a shot. I am designing an internal pipe gripping device. I have a center mandrel with several ramps on it. My slip/die will have corresponding ramps and the external surface will have teeth to grip the ID of the pipe. Pretty simple. In my simulations i am showing i will need a yield of 150ksi so i wont crush the slips. I'd like to have a case hardness of at least 60 HRC and min depth of .015 to .020. This part will be machined out of 9" round bar then using and EDM split into 6 sections. The question i have is what material will be good for this? (I also need some toughness, If the slip would beak, it would then be stuck in the pipe) I've had several suggestions but none seem to fit all the requirements. The Nitralloy 135 seemed to have to low of a yield, H13 seems like a good candidate, but is difficult to machine ( Turning the OD and maching teeth) aslso fairly expensive. Any other suggestions?
RE: High strength core with hard surface
Ted
See this site for steels http://www.oakleysteel.co.uk/high-strength-steel-p...
I would use a medium carbon steel and harden the outer surface to suit my requirements, steel grades S890Q and the grade below will exceed your strength requirement.
