Free standing cantilever wall resisting wind (LRFD)
Ladies and Gents,
I am designing a cantilevered wall with exposed footing (toe and heel doesnt have soil on top. Wall just sits on the ground). I am trying to design it with LRFD and ASCE 7-10. I understand that ASCE 7-10 wind load has been factored already (higher speed). So when I calculate the overturning moment from the wind, I use 1.0 load factor (eq 16-6 IBC) and used 0.9 for my resisting moment on the concrete DL. My questions are:
1. For overturning, do I just have to make sure the resisting moment is larger? It is LRFD design method so I just have to make sure resisting is equal or larger than the overturning correct? I do not need to use 1.5 factor of safety?
2. For checking sliding. Do I just use the pressure I have (1.0 load factor since ASCE 7-10 is already factored) and make sure the normal force (0.9 load factor) multiplied by the friction coef between soil and concrete is larger than the wind force? Is there some kind of reduction for the resisting friction force?
RE: Free standing cantilever wall resisting wind (LRFD)
Maine EIT, Civil/Structural.
