Exterior Wood Wall - can diagonal member be used in lieu of sheathing
In a cottage, the architectural drawings show no wood sheathing on the exterior face and 1/2" gypsum wallboard on the interior face. The contractor has provided a diagonal wood member.
The architectural drawings call for:
Exterior cladding (contractor used vinyl cladding)
1.4" rigid insulation
Metal corner bracing
2x6 studs @ 16
R23 bib insulation
6 mil vapour barrier
Since there is no wood sheathing, presumably the diagonal member must take all the wind load down to the foundations.
Is that normally done?
Is it ok?
What is meant by "metal corner bracing"?
2x6 studs @ 16
R23 bib insulation
Is it ok?
RE: Exterior Wood Wall - can diagonal member be used in lieu of sheathing
Don't know what code you are under.
http://www.finehomebuilding.com/design/departments...
Are there any holddowns?
Mike McCann, PE, SE (WA)
It's crap, though. You can't make the loads work in statics. Gyp sheathing would make more sense. Of course, there is some requirement (I believe) for some kind of exterior covering to keep stuff from flying through the wall during a high wind event.
It is not as good as sheetrock or GSB. The GSB is stiffer, so use that value for the shear. The let-in bracing is just extra.
Where a permanent let-in diagonal wood brace has been used, or a metal corner brace as called for on the drawings, does that make sheathing on the exterior face of the studs unnecessary?
Can the 1/2" gypsum wallboard on the interior side of the wall studs serve to take the place of the exterior sheathing, as far as the structural aspect is concerned to resist wind forces?
The Code is the Ontario Building Code, Part 9. It is very similar to the National Building Code of Canada.
CSA O86 clause 9.5.4. and tables 9.5.1B and 9.5.4
NBCC 9.23.13.1.2.(a).(ii)
