secure and normal supplies
I know that instrumentation usually runs off a secure supply and any heaters, lights etc would run off an auxillary supply.My question is Can you interchange these and have heaters etc running from a secure supply and instruments from an auxillary or have both ie heaters and instruments both running from a secure supply or both running from an auxillary supply?
thanks
thanks
RE: secure and normal supplies
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
If a "secure" power means a filtered or UPS-backed power supply, again - There is little logic to "protecting" a simple heater against power surges or lightening strikes or loss of power until the more sensitive electronics and controls are backed up and protected. Back Up power is expensive, in general, no company is going to pay for the maintenance and extra wiring and controls expense of BU secure power supplies unless they have to.
