Ansys workbench 14.0 error "ansysWBU.exe has encountered a problem ....."
Hi, everyone! I am new here, nice to meet you!!!
Now I am trying to do a random vibration analysis of a pipe. In the simulation, a spring connection is attached to connect the body with the ground. When I come to random vibration part, I need to add an acceleration PSD to the ground side of a spring. To do that, I clicked this spring connection as the Boundary condition to add the PSD, it suddenly gives me an error "ansysWBU.exe has encountered a problem ....." and Mechanical shut down itself.
I tried many advice online but still can't fix it. Any new suggestions? Thanks!
By the way, I am using ANSYS 14.0 with WIN 8.
Thanks!!
RE: Ansys workbench 14.0 error "ansysWBU.exe has encountered a problem ....."
Try without windows 8! dazed
Suggestion: they recommend me Heron Rotordynamics software (at www.heronrd.com Link or info[at]heronrd.com). It's online and you don't need solving troubles with your operating system because you can use it with a web browser only.
Regards.
