API creating simple geometry
I am trying to draw circle using API.
If I use feCircle3Point( pt1, pt2, pt3, messages ) method which creates circle in 3D space, then the boolean messages does not seem to work. I do not want the message to be displayed in the messages box. So I put "False", but it still shows up "Curve xx created" in the box.
If I use other methods, they create circle in defined workplane. And here the messages boolean works. But using this I am not able to define workplane through API. And I do not think "Defining Plane methods" are similar to "Defining workplane"?
Can anybody help me with this?
Thank you
Thank you
RE: API creating simple geometry
Which version are you using? This doesn't happen on v11.1.1, message are correctly turned off by the boolean.
