Proe/Creo with Enovia
Is there anybody out there who uses proe/creo with Enovia?
What are your opinions and experiences on this combination?
Does it work well?
Does it work well?
RE: Proe/Creo with Enovia
If you have specific questions, I'll be glad to talk to our admin and get you some feedback.
-tg
http://xternal.me
Did you ever use PDMLink?
PDMlink works buy storing data in a workspace which is linked with commonspace(database). Certain data management tools are disabled in proe when using PDMLink. This is because renaming and deleting of objects can only be done in the workspace browser. Also your working directory is in fact the workspace. Does Enovia work this way?
I saw a small demo and was told that you only use Enovia if you want to actually checkin, otherwise it is as if you are saving in windows folders/directory structure.
Enovia is just used for our part number assignment and engineering change processes. The PDF output from our ProE/PDMLink checkin process is stored in Enovia but not the actual ProE models.
-tg
http://xternal.me
