How to select the connected inner faces all at once?
How to select the connected inner faces all at once.
For example, I have a hollow pipe which is lengthy & bends in many directions. I want to select all the inner faces of pipe at once, without individually selecting the faces. Is there anyway to do that?
RE: How to select the connected inner faces all at once?
maybe check if that option is available in whatever the command is that you are utilizing
