oil cup gets frequent empty out
This is a centrifugal pump which this subject oil cup is attached to.
what can be possible causes of a constant level oiler getting empty out frequently.
1)ingress of air in oil cup due to crack in oil cup.
2) ingress of air through the joint where oil cup is fixed to bearing housing
3)leakage from shaft oil seals
4)chocked vent hole of bearing housing.
Is there any other reason which can cause this problem.??
thanks
thanks
RE: oil cup gets frequent empty out
Johnny Pellin
If you can be more specific on which make and model of oiler you are using, it would be helpful.
