Bystar 4020 stainless problems
Hi, New to the forums and also I'm mew to laser cutting. At my work we have a Bystar 4020 6000w the laser isn't to old "i can't remember the hours in up time", but I know it's 4 to 5 years old. We cut every thing from 16ga to 1" m.s. and 16ga to 5/8 304 & 316 stainless. The problem I'm having is on .375 and greater on stainless. I can get it to cut, but no matter what I try I still get slag on the bottom of the plate. I've tried dropping the feed rate, lowering the focus etc.. nothing seems to help. also when we cut .500 you have to lower the n2 gas pressure from 18 to 14 or you will get a gas jet error (cnc stop). Any input would be appreciated.
p.s. all the mild steel cuts fine besides the .750
RE: Bystar 4020 stainless problems
Chris Krug http://krugtech.com/
Maximum Up-time, Minimum BS
