Does a large PSV adjust its opening to flow only the inlet feed to the vessel?
I was wondering how the PSV behaves when it reaches the set point and opens. for a PSV sized for a blocked outlet relief load, it will be sized for the flow rate into the vessel. After some years, the production might be less and the required relief load will be less, however, the PSV still has the same size required for the initial larger relief load. if at low feed to the vessel, the outlet gets blocked and the pressure reaches the PSV set point, the PSV will open. what will be the flow rate from the PSV? is it the original designed flow rate? in this case the pressure will drop and the PSV will close and then opens when the pressure builds up again. Or will the PSV adjusts its opening to relief a flow equal to the inlet feed to the vessel?
I am carrying out a study on the flare header and it is showing that there is an issue at the original designed relief flow rates. The current production rate is less than day one, so does this mean that the relief flows for blocked outlet will be also less which will solve the issue on the flare header?
RE: Does a large PSV adjust its opening to flow only the inlet feed to the vessel?
If the volume of the protected system is the same and the flow into the system has decreased, then the PSV opens and closes less frequently.
Good luck,
Latexman
Technically, the glass is always full - 1/2 air and 1/2 water.
This is what I think. At original inlet rates to the vessel and at blocked outlet case, the PSV will be continuously flowing the designed flow rate for its size. at lower inlet to the vessel than the original design, the PSV will be still flowing the same rate it was designed for but in cycles as it will be opening and closing. This means that the flare header will be exposed to the same flow rate but in cycles which indicates that the risk now is higher than before because of the cyclic behavior.
Can the type of PSV (conventional, balanced or pilot) have an effect, or the PSV will be always either fully open or closed?(the fact that the PSV might not seat later at pressures lower than opening setting is not part of this discussion)
Only a modulating pilot operated PSV can do the job, i.e. can adjust its opening to momentarily flow; then there would be no cyclic behavior in PSV relieving toward flare network...
When evaluating a flare header, use the required flowrate. For tailpipes, one uses the rated capacity of the valve, and that's true regardless of whether the tailpipe discharges to atm or a flare header. If you're using a software program (e.g. Flarenet) for modeling the flare system, the program will automatically switch from rated flowrate to required flowrate once the stream exits the tailpipe and enters the flare header.
For this specific problem, it sounded like you were saying that the required flowrate is lower than the original valve used in the PSV design. If so, then you can update the PSV documentation (update the required flowrate) and use that lower value in the flare header rating. Alternatively, you can proceed with using the current required flowrate value in the flare rating. The flare load may turn out to be OK based on this value, even though you know that it's higher than the real value.
You mentioned in your first post:"... there is an issue at the original designed relief flow rates" for which the main point is lack of adequate info and detail. Can you clarify a bit more about mentioned issue?
OK, I will try to clarify it more.
The flare header is already sized and installed. It was sized for a certain required load. the Flare header seems to be incorrectly sized as it shows locations of choked flow.
some people mentioned that there should be no issue now because the required relief load is now less due to less plant production. However, I think that this is not accurate. the PSVs are still of the same size installed for the large required relief load and they are still set at the same pressure. so I think that although the required relief load is less, the actual load will be high because the PSV will be going on fully open position and flow its rated flow rate. but since the input to the vessel is low, the pressure will drop and the PSV will close. and the cycle will be repeated. there is someone else who argued and said that the PSV will although rated for larger flow rate it will flow only the required flow and I think that this is incorrect. Clarifying this point is very important because it changes the whole case from high risk classification into safe one.
http://www.eng-tips.com/viewthread.cfm?qid=365370
The PSV with lesser incoming load than before due to less production rate might be opened momentarily at the set point, relieving the rated load and reseat back, i.e. sort of unstable operation due to lower actual generated load. But it might even, with high degree of probability, not attain a full lift to relieve the rated load because there isn't the sustained generation of previous higher load. Then i think the PSV can relieve a load mostly not higher than required flow rate leading to no excess load on flare header to be a source of concern...
But re-reading API 520 (8. ed) im now i doubt if my initiall position is wrong. API 520 section 4.1.1.7 reads: Flow is restricted by the opening between the nozzle and the disc until the disc has been lidted from the nozzle seat approximately one quarter of the nozzle diameter. After the disc haas attained this degree of lift flow is then controlled by the bore area rather than by the area between the seating surfaces."
So if i read this correctly flow will only be dependant on upstream pressure and orifice area for lift above 1/4 of the nozzle diameter. This together with figure 6 supports the statements that the valve will effectively relive close to design capacity (slightly lower because the pressure imo will not reach 110% - but design value may be used because its impossible to say exactly what the actual relieving pressure will be). Then inaccordance with figure 6 pressure will decrease below set-p - and the valve will reseat fully. If the conditions that lead to overpressure is still there - the pressure will once again increaes ntil the PSV opens. etc.
Best regards, Morten
It could well be that as the valve disc approaches the seat, that so long as the flow is sufficient to hold open the disc that the valve in effect becomes a throttling device on the basis that the flow is no longer enough to hold open the valve at its 100% opening.
I can only suggest you ask the vendor what the valve characteristics are in this respect or even do a few tests yourself or off line to find out how the valves respond to high pressure, but lower flow.
In some parts of the plant I imagine that some valves will now operate in a open / close arrangement, especially where there is is only a small volume to relieve, but where a larger one exists which can even out the open / close popping, then below a certain flow rate as a percent of its rated duty (maybe 25-30%), the relief valves could easily sit partly open.
As you well aware PSV chattering might be created due to several rerasons mainly included: 1)Undersized inlet line, 2)Undersized outlet line, 3)Oversized PSV itself. In current discussion the chattering due to third reason are being considered i.e. a PSV which has rightly been sized per governing case would be oversized for other cases. But the point is that the PSV is how much undersized for the cases other than sizing case; and as i mentioned if, for any case, degree of oversizing wouldn't be so high the PSV might be under cyclic open-close conditions but with a time lag between opening and closing points not being called chattering; and on the other hand if degree of oversizing would be high, say for lower than 25% of the rated flow, rapid opening-closing of the PSV will lead to chattering and subsequent PSV damage...
That fact that you will have other cases that the design case cant be avoided! So of course you can find cases where the PSV will be (much) too large - but the valve still have to be able to cope with the design case. Thats just the way it is. I think this whole tread considers the design case - and any required oversizing and impact on header and falre capacity.
Howvere, as also other pointe out much earlier there are valve type sch as modulating pilot types tha can cope with this dilemma.
