how to select motor HP for screw conveyor
Does any body know how to select motor horsepower for a screw conveyor? The conveyor ID is 458mm, screw shaft runs at 10RPM. Total length is 2.5m. The material in the conveyor is sweet corn.
Any answer or formula is highly appreciated.
thank you
RE: how to select motor HP for screw conveyor
You could try contacting a Company called Fenner Transmission in Blackburn i think.  They specialise in drives of all kinds and may help if you ask for their technical people.  I think their tel no is 01254 674171
Thank you Brain21.
You can try with the Martins sprocket-gear handbook or
this site
http://www.martinsprocket.com
Screw conveyor manufacturers typically have a power requirement chart in their brochure / catalogue.  I have one right here !  feel free to call me at 403 278 7604
mac
Thanks IvanR and Macmil. I'll find the power rating chart from conveyor manufacturers.
28/11/02
