Fasteners with nylon or polyester locking elements. What is max number of install/remove cycles?
I've been looking for the maximum number of install/remove cycles for screws and nuts having nylon or polyester locking elements. What is that number and how do you justify it?
Tunalover
RE: Fasteners with nylon or polyester locking elements. What is max number of install/remove cycles?
Probably best, since a bolt/screw with badly finished threads might ruin the insert on the first install
