instrument air tube heat loss rate
I am measuring differential pressure in a separator. Operating temperature is 500F but differential pressure switch is rated at only 200F. Using 1/4"OD stainless steel tubing to connect the switch outside the insulation. How much tube do I need to cool the air 300F?
RE: instrument air tube heat loss rate
The ID is too small for convection, so it'll strictly be by conduction through the air as well, which is on the order of 5 mW
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
