Evaluation of anti-log
Greetings from England
In my kind of work, log function is very unusual.
I have found that log(number)= works fine - in that answer is correct.
y: 4.601 log(y) = 0.66285
But now I need to evaluate the anti-log...can be easily done on pocket
calculator (via inverse/shift); but how is it done in Mathcad?
By experimentation...
10^log(y) = 4.601 works, but is it correct procedure?; any neater solution?
I use Mathcad 2000.
Ed
Ed Clymer
Resinfab & Associates
England
RE: Evaluation of anti-log
Or create your own function: alog(x):10^x where "x" would your previous log()
Thanks to IR stuff and Occupant.
IR stuff is quite correct, back to basics.
Occupant has neat solution, I will give that a try.
Help appreciated.
Ed
Ed Clymer
England
