Advice/ help needed; macro code for selecting Absolute Axis system in Catia
Hi!
I need som help with my macro code.
I'm working on a macro to create drawing tables with X, Y and Z coordinates for 3D points. So far I managed to get it working properly and it spits out nice tables, no problem there.
However, I want it to always extract coordinates relative to the absolute axis system. By default it picks the local axis, and that is fine as long as it's in the same position as the absolute, but if the local is moved the coordinates become inaccurate.
Below is a sample of my code. It uses a for loop to cycle the selected points and pick X, Y and Z. The code highlighted in green accesses Catia's measure function.
Is there a way select a specific axis system as point of origin? I've searched this forum but haven't been able to find anything that's been helpful to my problem.
If other users are interested in this type of macro I gladly post the whole code. I also have another macro that exports the same data to Excel.
Grateful for any help
CODE --> *.catvba
'create the table itself Set MyTable = myView.Tables.Add(100, 100, numberOfPoints + 2, 4, 7.5, 20) '********************************************************************************************************************************************** Set TheSPAWorkbench = CATIA.ActiveDocument.GetWorkbench("SPAWorkbench") ' set TheSPAWorkbench For i = 1 To numberOfPoints 'create correct number of rows Set Element = selection1.Item(i) Set selPoint = Element.Value Set TheMeasurable = TheSPAWorkbench.GetMeasurable(selPoint) TheMeasurable.GetPoint coords 'get coordinates from Measurable MyTable.SetCellString 2 + i, 1, letter & i 'add point index xPoint = Round(coords(0), 1) 'check if coordinate has decimals If xPoint = 0 Then 'avoid division with zero MyTable.SetCellString 2 + i, 2, "0,0" 'add 0,0 ElseIf Int(xPoint) / xPoint = 1 Then 'if integer MyTable.SetCellString 2 + i, 2, xPoint & ",0" 'add ",0" Else MyTable.SetCellString 2 + i, 2, Round(coords(0), 1) 'else, use 1 decimal End If yPoint = Round(coords(1), 1) 'same procedure for y and z If yPoint = 0 Then MyTable.SetCellString 2 + i, 3, "0,0" ElseIf Int(yPoint) / yPoint = 1 Then MyTable.SetCellString 2 + i, 3, yPoint & ",0" Else MyTable.SetCellString 2 + i, 3, Round(coords(1), 1) End If zPoint = Round(coords(2), 1) If zPoint = 0 Then MyTable.SetCellString 2 + i, 4, "0,0" ElseIf Int(zPoint) / zPoint = 1 Then MyTable.SetCellString 2 + i, 4, zPoint & ",0" Else MyTable.SetCellString 2 + i, 4, Round(coords(2), 1) End If Next
RE: Advice/ help needed; macro code for selecting Absolute Axis system in Catia
Hi again
Thanks for the tip.
I've been playing around with the code for getting coordinates from a specified axissystem, but I've run into a problem. Hope you can help me.
If you check the code under you link, the public function LCS uses a custom datatype named iPct. When I try to get coordinates for the points in a polyline, I get an error saying "Compile error: ByRef argument type missmatch" and it points towards the point I'm trying to measure. What I understand from the help-file in VB, there is a conflict in data types. What data type or conversion method shall I use to make it accept the point. I've previously used getMeasurable on the point elements because in my case they are not always normal points, but can be projects or datum points, and the normal getPoint method does not work on points that aren't "true" points.
I'm somewhat familiar with vba basics but this coding is a bit over my head.
(The point of malfunction is marked in green.)
CODE --> catVBA
'variables
Dim errorMes As Variant
Dim MeasurePoint, MeasureLength As Measurable
Dim polyline1NrOfElements, numberOfPoints As Integer
Dim foundTables, errorRep As Boolean
Dim parentName, prodName As String
Dim axisSystem1 As AxisSystem
Public selection1 As Selection
Public selectionOaxis As Selection
Public productDocument1 As Document
Public product2 As Product
Dim objGEXCELapp As Object
Dim objGEXCELwkBks As Object
Dim objGEXCELwkBk As Object
Dim objGEXCELwkShs As Object
Dim objGEXCELSh As Object
Public catTargetDrw As String
Public catHeadline As String
Public catPointIndex As String
Public catTol As String
Public catUserChoice As Integer
Public XLheadline As String
Public XLpointIndex As String
Public XLtol As String
Public XLuserChoice As Integer
Sub CATmain()
    'On Error GoTo errorHandler  'errorhandlng
        Set selection1 = CATIA.ActiveDocument.Selection 'handle the selection in catia
            If selection1.Count = 0 Then    'if selection is empty display message
                MsgBox ("Nothing selected! Please select a polyline or at least one point.")
                    Exit Sub
            End If
    'create main origin part and axissystem
    Set productDocument1 = CATIA.ActiveDocument
        Set product1 = productDocument1.Product
    Dim products1 As Products
    Set products1 = product1.Products
    Set product2 = products1.AddNewComponent("Part", "")
    Dim prodCount As Integer
    prodCount = products1.Count
    Dim prodName As Variant
    prodName = products1.Item(prodCount).PartNumber
    prodName = prodName & ".CATPart"
    Dim documents1 As Documents
    Set documents1 = CATIA.Documents
    Dim partDocument1 As PartDocument
    Set partDocument1 = documents1.Item(prodName)
    Dim part1 As Part
    Set part1 = partDocument1.Part
    Dim axisSystems1 As AxisSystems
    Set axisSystems1 = part1.AxisSystems
    Set axisSystem1 = axisSystems1.Add()
        'create axissystem
        axisSystem1.OriginType = catAxisSystemOriginByCoordinates
        Dim arrayOfVariantOfDouble1(2)
        arrayOfVariantOfDouble1(0) = 0#
        arrayOfVariantOfDouble1(1) = 0#
        arrayOfVariantOfDouble1(2) = 0#
        Set axisSystem1Variant = axisSystem1
        axisSystem1Variant.PutOrigin arrayOfVariantOfDouble1
        axisSystem1.XAxisType = catAxisSystemAxisByCoordinates
        Dim arrayOfVariantOfDouble2(2)
        arrayOfVariantOfDouble2(0) = 1#
        arrayOfVariantOfDouble2(1) = 0#
        arrayOfVariantOfDouble2(2) = 0#
        axisSystem1Variant.PutXAxis arrayOfVariantOfDouble2
        axisSystem1.YAxisType = catAxisSystemAxisByCoordinates
        Dim arrayOfVariantOfDouble3(2)
        arrayOfVariantOfDouble3(0) = 0#
        arrayOfVariantOfDouble3(1) = 1#
        arrayOfVariantOfDouble3(2) = 0#
        axisSystem1Variant.PutYAxis arrayOfVariantOfDouble3
        axisSystem1.ZAxisType = catAxisSystemAxisByCoordinates
        Dim arrayOfVariantOfDouble4(2)
        arrayOfVariantOfDouble4(0) = 0#
        arrayOfVariantOfDouble4(1) = 0#
        arrayOfVariantOfDouble4(2) = 1#
        axisSystem1Variant.PutZAxis arrayOfVariantOfDouble4
        part1.UpdateObject axisSystem1
        axisSystem1.IsCurrent = True
        part1.Update
        Dim settingControllers1 As SettingControllers
        Set settingControllers1 = CATIA.SettingControllers
        Dim visualizationSettingAtt1 As VisualizationSettingAtt
        Set visualizationSettingAtt1 = settingControllers1.Item("CATVizVisualizationSettingCtrl")
        visualizationSettingAtt1.SaveRepository
                    mainForm.Show
                If catUserChoice = 1 Or catUserChoice = 2 Then  'user choose to create a polyline table
                    catPolyline
                ElseIf catUserChoice = 3 Then  'user choose to create a point table
                    catPoints
                ElseIf XLuserChoice = 1 Or XLuserChoice = 2 Then
                    XLpolyline
                ElseIf XLuserChoice = 3 Then
                    XLpoints
                End If
errorHandler:   'error messages
    If Err.Number = -2147467259 Then
        errorMes = MsgBox("No active 3D document!" & vbNewLine & "Load a 3D document and select a polyline or at least one point.", vbCritical, "Error!")
            Err.Number = 0
    End If
End Sub
Sub catPolyline()
            'Set selection1 = CATIA.ActiveDocument.Selection
                Set polyline1 = selection1.Item(1)  'pick first element (the polyline) of the selection in Catia
                    If polyline1.Type <> "HybridShapePolyline" Then     'check if the object selected is a polyline
                        errorMes = MsgBox("Wrong type of object selected! Please select a polyline.", vbCritical, "Wrong type of object!!")
                        Exit Sub
                    End If
                    Set myPolyline = polyline1.Value
                        polyline1NrOfElements = myPolyline.NumberOfElements  'count number of points in the polyline
    'start table creation process
    CATIA.Windows.Item(catTargetDrw).Activate     'switch to drawing window
        Set myDoc = CATIA.ActiveDocument    'define active document and view
            Set mySheet = myDoc.Sheets.ActiveSheet
                For i = 1 To mySheet.Views.Count                'check if drawing view "TABLES" exists
                    Set myView = mySheet.Views.Item(i)      'set view
                        If myView.Name = "TABLES" Then             'if "TABLES" exists activate view and exit for-loop
                            Set myView = mySheet.Views.Item("TABLES")
                                myView.Activate
                                    foundTables = True
                                        Exit For
                        End If
                Next
                        If foundTables = False Then             'if "TABLES" doesn't exist, create it and activate
                            Set myView = mySheet.Views.Add("TABLES")
                                myView.Activate
                        End If
        Dim mytable As DrawingTable
        Set mytable = myView.Tables.Add(100, 100, polyline1NrOfElements + 3, 5, 7.5, 22)
            'add labels
            mytable.SetCellString 1, 1, catHeadline
            mytable.SetCellString 2, 1, "POINT"
            mytable.SetCellString 2, 2, "X"
            mytable.SetCellString 2, 3, "Y"
            mytable.SetCellString 2, 4, "Z"
            mytable.SetCellString 2, 5, "RADIUS"
                'format the table
                mytable.MergeCells 1, 1, 1, 5
                    mytable.SetCellAlignment 1, 1, CatTableTopCenter
                mytable.MergeCells polyline1NrOfElements + 3, 1, 1, 5
                    mytable.SetCellAlignment polyline1NrOfElements + 3, 1, CatTableTopCenter
    'coordinate extraction process
    Dim TheSPAWorkbench As Workbench
        Dim MeasurePoint, MeasureLength As reference
            Dim oRad As Length
                'Dim activePoint As Object
            If catUserChoice = 1 Then  'normal polyline
                For i = 1 To polyline1NrOfElements       'iterate through all poinst of polyline
                    myPolyline.GetElement i, activePoint, oRad
                       Set MeasureLength = TheSPAWorkbench.GetMeasurable(myPolyline)
                        myPolylineLength = MeasureLength.Length
                    LCS axisSystem1, activePoint
                    If oRad Is Nothing Then RadiusAtPoint = False Else: RadiusAtPoint = True                ' check if Radius at point
                    'add point index
                    mytable.SetCellString 2 + i, 1, catPointIndex & i
                    xPoint = Round(Diff.X, 1) 'check decimals
                            mytable.SetCellString 2 + i, 2, "0,0"       'add "0,0"
                        ElseIf Int(xPoint) / xPoint = 1 Then        'check if integer
                            mytable.SetCellString 2 + i, 2, xPoint & ",0"       'add ",0"
                        Else
                            mytable.SetCellString 2 + i, 2, Round(Diff.X, 1)     'else, use 1 decimal
                        End If
                    yPoint = Round(Diff.Y, 1)        'same procedure for y and z
                        If yPoint = 0 Then
                            mytable.SetCellString 2 + i, 3, "0,0"
                            mytable.SetCellString 2 + i, 3, yPoint & ",0"
                        Else
                            mytable.SetCellString 2 + i, 3, Round(Diff.Y, 1)
                        End If
                    zPoint = Round(Diff.Z, 1)
                        If zPoint = 0 Then
                            mytable.SetCellString 2 + i, 4, "0,0"
                            mytable.SetCellString 2 + i, 4, zPoint & ",0"
                        Else
                            mytable.SetCellString 2 + i, 4, Round(Diff.Z, 1)
                        End If
                    If RadiusAtPoint Then
                        radPoint = Round(oRad.Value, 1)     'same method as above
                            If radPoint = 0 Then
                                mytable.SetCellString 2 + i, 5, ""
                            ElseIf Int(radPoint) / radPoint = 1 Then
                                mytable.SetCellString 2 + i, 5, radPoint & ",0"
                            Else
                                mytable.SetCellString 2 + i, 5, Round(oRad.Value, 1)
                            End If
                    End If
                Next
polyLength = Round(myPolylineLength, 1)  'add length, check integer, same method as above
                    If Int(polyLength) / polyLength = 1 Then
                        mytable.SetCellString polyline1NrOfElements + 3, 1, "TOTAL LENGTH = " & polyLength & ",0" & catTol & " MM"
                    Else
                        mytable.SetCellString polyline1NrOfElements + 3, 1, "TOTAL LENGTH = " & Round(myPolylineLength, 1) & catTol & " MM"
                    End If
                            Set selectionOaxis = productDocument1.Selection     'delete external part document with axissystem
                                selectionOaxis.Clear
                                    selectionOaxis.Add product2
                                        selectionOaxis.delete
                            selection1.Clear
                            MsgBox "Polyline coordinate table completed!"  'display message of completion
