what formula gives oil temperature at a certain pressure?
Dear professional engineers,
i am working on hydraulic circuit design, and the maximum pressure at the cylinder is 24.000 PSI, and i need to select the right oil for the circuit, so i need to know its temperature at that pressure, so i select accordingly
can't get the formula which shows the relation between the pressure and temperature of oil used at hydraulic circuits, anyone can help?
will appreciate your help,
Thanks in advance
Thanks in advance
RE: what formula gives oil temperature at a certain pressure?
You really need to get some local help from someone with more experience in hydraulic system design.
Mike Halloran
Pembroke Pines, FL, USA
Process conditions and pump/motor heat dissipation are the significant factors you need to look at for temperature.
If you have built the system right there should be an accumulator to prevent the increased pressure. This is why pressure and temperature are not related the way you were thinking.
If you do not have an accumulator but have instead sealed your system you can get an estimate of the pressure by using the CTE of the fluid and the CTE of the container and do a volumetric estimate as a function of temperature.
There is no relationship between pressure and temperature. Except: temperature rise due to compression, which is generally ignored; expansion of fluid due to increasing temperature and the resulting pressure if the fluid is constrained, not free to expand.
Ted
well, i know now that there is no relation between the oil pressure and the temperature at liquids, i thought there is a relation like as the gases, but i understand now
one more question please, at the same thread and not to open new one which is:
i am considering manual pump, with built in manual relief valve, my question, is the manual relief valve which exist at the manual pump, can be opened manually at anytime while loading, and release the pressure to the tank?, or it only is adjusted manually to open at a certain range of pressure?
will appreciate your response,
Ted
Thanks for your help, i appreciate that
