Foundation saddle loads due to OPE/HYD/wind/seismic
Hi all,
I am new to PVelite software.But i am to verify (vendor document) Pvelite design report for my project.
Can any one explain that saddle loads (i.e.vertical/transverse/longitudinal shear) due to OPE/HYD/wind/Seismic cases separately generated from PVelite software?
In my current report,Saddle loads due to operating/Hydro-test case have been generated & Followings have been noticed
In OPE case report,
Saddle reaction force due to wind Ft & Fl and due to seismic Fst & Fsl is done.
In HYD test case report,
Only Saddle reaction force due to wind Ft & Fl is done.
In both case,summary of load has been given with vertical/transverse/longitudinal shear loads.
I am bit confused about how summary loads arrived at each cases in report.Can anyone elaborate this checking methodology?
In OPE case report,
RE: Foundation saddle loads due to OPE/HYD/wind/seismic
No one would bother to go in technical details for something you are completely out of your world. Worst still, you have accepted to do an engineering review for a design you have no idea what it is. Have the decency and tell your managers that for the sake of saving a few lives of plant operators, you will not review the pressure vessel calculations. Do not endanger the life of fellow humans with your incompetent selfish act, that you call engineering.
Thanks for your advise for my first ever post in this website.
I guess purpose of this forum is to get some engineering tips & make yourself confidence.But Your reply seems that i should not post anything here unless you are being expert.Nobody born as pressure vessel expert. My humble request to you that not to discourage anybody.Correct me if i am wrong.
We do NOT want innocents killed because YOU believe you can learn pressure design and and fabrication over the internet. IF you had the background and training to design and critique pressure vessel analysis already, and YOU were the one needing specific guidelines or answers to specific questions, then - yes! - asking questions here is a good and important step.
You - in the opinion of the professionals reading your questions and the level of experience evident in your questions - do not yet have the knowledge to do this task yet. You may aquire it through work, through reading, through additional classes or your company's training and assignments. But not here on line by open questions. That method is not safe for other people to work around, for other companies to have their equipment exposed to the hazards you will create.
I realized that being novice,I shouldn't have posted this basic questions.Sorry for inconvenience
In PV elite you may have consider o% seismic load for hydrotest condition..
In summary i think PV elite shows the seismic / wind load,whichever is more...
Bmechz
I have not used PV-Elite since long time but there is standard practice for considering 0% seismic load while hydrotesting of equipments.
Normally we consider 25% or 33% wind loads or as per client specification while hydrotesting.
In case of operating conditions, PV-Elite determines worst load cases for wind and seismic and designs saddle for highest load.
Hope, I clarified your doubts.
