Setting the PDF file export name - Possible?
Hello
I have a question regarding the export of the PDF in NX (8.5)
Is it possible to set the filename of the PDF to be something else i.e:
BASE012345_A_PDF --> BASE012345_A_RELEASED
At present the default is _PDF.
Additionally, would it be possible to get NX to automatically append the 2D file sheet name in place of the _PDF everytime you do an export...?
Thanks for having a look - all responses greatfully received.
Rob.
Rob.
Solid Edge; I-Deas 7 to 12; NX4 to NX8.5 / TeamCenter 9.1 & Ansys 14.5
RE: Setting the PDF file export name - Possible?
However, I'm not sure that applies when NX is used with TC.
Anthony Galante
Senior Support Engineer
NX5.0.6, NX6.0.5, NX7.5.5, NX8.0.0 -> NX8.0.3
NX8.5.0 -> NX8.5.3, NX9.0.0 -> NX9.0.2, NX10 Beta
www.nxjournaling.com
