datos de motor siemens elTctrico de 15 HP 1745 rpm 220- 440 voltios
que tal amigos tengo un problema con un motor Siemens de 15 HP 1745 rpm 220-440 voltios, tiene 48 ranuras el estator, me han dado el motor sin ningún alambre en el estator, les agradecería me envíen los datos del calibre del alambre de cobre, el numero de espiras de las bobinas, numero de bobinas y paso de las bobinas, espero que tengan estos datos y el tiempo para poder enviarme estos datos, muchas gracias de antemano.
RE: datos de motor siemens elTctrico de 15 HP 1745 rpm 220- 440 voltios
Have you seen this forum?
Translation Assistance for Engineers - Owner: IRstuff
This forum is designed addressing translations of engineering terms and concepts for non-English technical questions
forum1529: Translation Assistance for Engineers
Bill
"Why not the best?"
Jimmy Carter
I can't answer but here is translation.
such friends have a problem with a Siemens motor 15 HP 1745 rpm 220-440 volts, has 48 stator slots, have given me the engine without any wire in the stator, I would appreciate data Submit gauge copper wire , the number of turns of the coils, number of coils and coil step, I hope you have these data and the time to send this data, thank you very much in advance.
Not sure he will understand an answer in English though.
Chuck
It is not likely that someone will have the original data exactly for your motor.
BTW, even the motor type is not listed .....
In this case, only the new winding data calculation can help. But, you must be able to measure and provide all the information needed to calculate.
Here is an explanation and an online form that must be filled. Also, the nameplate photo should be attached.
http://winding.wix.com/design
