Maximum Stress on Shell element in Ultimate Limit State Design Method
IF we design a plate based on ultimate limit state method, the stress on shell element with elastic model on SAP2000 can give higher stress value than yield stress. To compare design approach and modeling approach, may be we need to model the plate using layer nonlinear shell element.
However, if I am modeling a rectangular plate, the plastic section modulus is 1.5 times higher than elastic section modulus. Can I simply check that the maximum stress on plate element is not higher than 1.5 times yield stress? If so, how should I check and compared the maximum stress results from SAP2000 when I am modeling a circular plate?
Any help please!
Any help please!
RE: Maximum Stress on Shell element in Ultimate Limit State Design Method
