NX CAM using work offsets
Is it possible to use a work offset on a 5 axis HAAS (Trunnion with a rotary) that does not use the center line of the rotary for a work offset? Have tried to set secondary MCS, 1 inch above the OD on a cylindrical part with OD holes. The rotary does not move in a canned cycle with out outputting X,Y values. If I set it to centerline of rotary it works fine. Is there any way to reference the axis of rotation?
RE: NX CAM using work offsets
Is it me or is there anyone else working with NX CAM?
Thousands of people use NX CAM every day.
I am not sure what kind of response you are expecting here. This is a public forum and many NX CAM users read it.
If you want to discuss in a forum, I suggest you explain the situation and your question more clearly, and post it in a more focused forum, like the Discussion Forum found in the Siemens Manufacturing Community at http://community.plm.automation.siemens.com/t5/NX-....
You can also contact GTAC or your reseller for help.
Mark Rief
NX CAM Customer Success
Siemens PLM Software
