NX7.5 - NX9 SKETCH DIMENSION ANIMATE SLIDER BAR NOT IN NX9.5
WHERE DO YOU FIND THE ABILITY TO ANIMATE SKETCH DIMENSIONS ON THE FLY IN NX9?? IN NX 7.5 THIS WAS AVAILABLE VIA A SLIDER BAR WHICH WAS INVOKED BY A (DOT DOT DOT ICON WHILE DIMENSIONING A SKETCH). IM NOT LOOKING FOR THE ANIMATE DIMENSION COMMAND WHICH IS AFTER THE DIMENSION WAS INSERTED.
RE: NX7.5 - NX9 SKETCH DIMENSION ANIMATE SLIDER BAR NOT IN NX9.5
Menu -> Edit -> Sketch Parameters...
...select the Parameter of interest and you can then edit it using a 'slider bar' as you could in NX 7.5.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
