NX9 threaded hole settings
Where in NX9 can you change the threaded hole settings. Say from UNC,UNF,NPT, Etc, Etc.
It was always below Boolean in NX8.5 and NX9. Seems to be gone now.
Scott
RE: NX9 threaded hole settings
Your dialog is probably in it's 'Less' state.
Go to the bottom of the dialog and you'll notice a little black arrowhead. If it's pointing downward, your dialog is in the 'Less' state. If you hover your cursor over this arrowhead it will indicate that if you click the arrowhead that you will see all the dialog options. Also, if you select the little 'gear' icon in the upper-Left corner of the dialog header you'll see the same options. Note that the state of a dialog, be it set to 'Less' or 'More', will be retained by Dialog Memory so that the next time you open that dialog it will be in the state that you last left it.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Bingo!
Thanks John!
Scott
