Pressure vessel, ASME VIII-1, UW-16, Nozzle attachment
Hello everyone!
I have a nozzle which is welded through shell and jacket plates. We are having a trouble making a fillet weld on the outside surface of a shell, because there is practically no access.
Is there any type of weld that allows making only full penetration groove weld without making a fillet weld on the backside?
RE: Pressure vessel, ASME VIII-1, UW-16, Nozzle attachment
Is it an option to project the nozzle inside the vessel?
Mike
Yes, the nozzle is projected inside the vessel. Pressure vessel of rectangular cross section externally reinforced by u-beams. U-Beams form a jacket around an inner vessel.
As I understand, if there is no fillet weld on the nozzle then it is not in accordance with sketches in figure UW-16.1. Should then strength calculation for the groove weld be performed UW-15? Or there any other rule in a Code, which allows making only inside full penetration groove weld ?
Thanks!
Sorry my bad English :)
If the nozzle is projected inside the vessel (your sketch does not show it as such) why not add the fillet to the inside?
Mike
Sorry for misleading you. The nozzle does not protrudes inside the vessel. It is flushed with the
vessel ID as it described on a attached sketch.
So, if fillet weld is not required, should then the dimension tw (Fig. UW-16.1 sketches (t) and (u)) of a weld be not less than tn nor less than 0.25 in as it reads in UW-16(e)(2) ?
If full penetration, I would say the applicable sketch is (d), omitting the fillet.
Mike
