Separation of methanol from water
I have to design a separation plant of methanol from water with around 5 liter per minute flow rate, please suggest low cost, high efficient method.
RE: Separation of methanol from water
How pure is the water?
How pure is the methanol?
What quality (percent efficiency) can you tolerate of the two streams after separation? Is 5% "polutted" methanol "good enough" when the streams are separated?
What is your budget?
What are your resources?
When do you need the system working?
(You can buy anything Fast, Cheap, or High Quality. Pick two of the three.)
