Parametric Analysis
Parametric Analysis
Is there a way to write a script in Femap API that creates and solves many load cases in one run? More like a parametric analysis of different analysis cases with a varying property of the model.
RE: Parametric Analysis
"On the human scale, the laws of Newtonian Physics are non-negotiable"
I have the same question as adampar.
I want to extract the .dat file to run them outside Femap.
I use the same load set combinations, and I just want to change the scale factor.
For example, 0.3*A+1*B+1*C
1*A+0.3*B+1*C
1*A+1*B+0.3*C
-0.3*A+1*B+1*C
Thanks.
Patricia
