composite progressive failure
I'm trying to simulate the progressive failure of a composite tube under tensile test with ortotropic properties, using implicit nonlinear solution (sol 400). I have entered linear elastic properties and failure1 (sol 400/600) with maximum stress failure criterion and progressive failure option but I don't have any result. When i cheked the f06.file I have found this message : USER FATAL MESSAGE 2016 (IFP6)
NO MATERIAL PROPERTIES EXIST.
0FATAL ERROR
where could be the problem?
0FATAL ERROR
RE: composite progressive failure
0FATAL ERROR
