determining suction and delivery lines of centrifuagal pump
For a centrifugal pump
what significant signs I can see from outside of a real pump mounted in a system in order to differentiate between suction and delivery lines of centrifugal pump ?
RE: determining suction and delivery lines of centrifuagal pump
Attach a photograph and someone here will help you.
Sometimes its possible to do all the right things and still get bad results
Johnny Pellin
are you sure ? I thought that was for the compressor only.
The only thing I can think about now is that the discharge might have a check valve while suction not . Maybe the discharge might have a flow control valve and suction not as well . Is there another sign we could tell ?
This is something you would normally recognize in pumping stations (booster pumps).
"If you want to acquire a knowledge or skill, read a book and practice the skill".
You wrote:"Well I don't have a picture its an engineering job interview question"
What is the job you are interviewing for?
It is easy to identify the the suction and discharge for an end suction pump. But not that simple for
vertical inline pump, Multistage, axial split case, VS6 type. Here the OP mentioned about a complete mounted system.
If the suction and discharge flanges are different sizes, the larger one is the suction.
If there is a check valve in one of the lines, that is probably the discharge.
Johnny Pellin
