How to set part name different from the file name?
Generally I save the part file with part name and part no. (eg. Shaft (01-23-456)). So in the assembly part list, the part name displays as 'Shaft (01-23-456)'.
I would like to display the part name and part no. separately in the corresponding cell of partlist, in the assembly drafting.
Is there any method to do that?
Thanks.
Thanks.
RE: How to set part name different from the file name?
what version of NX are you on ?
are you on Teamcenter?
You could try this:
1) Save you part file with "01-23-456" as the file name.
2) In this file create a custom property called what ever you like, for this example i'll use "DESCRIPTION" and enter "SHAFT" in this custom property.
3) Save this file and Use this file in an assembly.
4) In this assembly file right click in the assembly navigator and go to "Properties" and then the "Column" tab. In the field listed "Attribute" enter the same name of the custom property you used in step 2) and hit "create" button and then "OK" to close this dialog.
5) Now you'll have a new column in the assembly navigator with the info you desire.
NX8
No.. Not using Teamcentre
@Hercalloy
Thankyou Hercalloy :)
Just note... that is but one way to do it (that i listed). If you poke around with my leads.. you'll see there is many ways to do things so you may find ways to do it more to your liking. :)
In the assembly drafting environment, in the properties window, I couldn't find the "column" tab :( please explain.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
