Spring steels
Spring steels
Spring steels
I am looking for books or technical references: "Effect of Silicon on Bauschinger effect in spring steels".
Thanks in anticipation.
I'm just one step away from being rich, all I need now is money.
( read somewhere on the internet)
RE: Spring steels
I have included some links below that you can review. You can do a more extensive search using Google Scholar and include the keywords "sag resistance" as this is correlated to the Bauschinger Effect, and will return more hits.
Study of Bauschinger Effect in Various Spring Steels
http://www.collectionscanada.gc.ca/obj/s4/f2/dsk1/...
Development of a New Kind of High Strength Spring Steel
http://www.jmst.org/fileup/PDF/2003225.pdf
High Sag Resistance Spring Wire for Automotive Suspension
http://www.shotpeener.com/library/pdf/1985033.pdf
The Past and Future of High-strength Steel for Valve Springs
www.kobelco.co.jp/english/ktr/pdf/ktr_26/021-025.p...
Super high strength valve spring steel with excellent fatigue and sag resistance
www.kobelco.co.jp/english/ktr/pdf/ktr_27/075-075.p...
RE: Spring steels
Thanks for the references please . As always stars for you!!
