Pipe Threads
Pipe Threads
How would one model a pipe thread (NPT) using cosmetic thread?
RE: Pipe Threads
Steve
http://www.3dlogix.com
RE: Pipe Threads
RE: Pipe Threads
RE: Pipe Threads
you can create a taper on the male that represents the major diameter and then the hole would be the minor. I guess I do this to the drawing looks correct. Remember that this will cause an interference if you perform a global interference analysis. To avoid this entirely, you can make the male the minor diameter and the female major. This will show a gap on the 3D model, but, should still ok on a hidden line view for 2D. Let me know if this helps, and if it does gimme a star!
RE: Pipe Threads
Old fashion lines used in standard drawing practice work fine on the drawings, and the taper is evident. We use ANSI B1.20.1 call out, and dimension L2 as the thread-engagement-depth for assembly drawings.
RE: Pipe Threads
