Partially Enclosed or Enclosed
Which one is more conservative to design (enclosed or partially enclosed)?
Which one results on higher wind loads on building?
Thank you
Thank you
RE: Partially Enclosed or Enclosed
Enclosed will result in more lateral force, ann partially enclosed in more uplift.
Mike McCann, PE, SE (WA)
In ASCE 7, internal pressure may act inward or outward. Internal pressure coefficients are + and -.
