Could someone help me with this callout problem
I can't figure out how to make the separator line only between the 1 and the 4 --not the entire callout
Has anyone else had this (file attached)
Brian Marchand-Die Designer
http://www.armotool.com/
NX 9.0.2.5 / PDW
Dell Precision T7610 w/Xeon ES-2609
16G Ram - Nvidia Quadro K5000
Win 7 Pro x64
RE: Could someone help me with this callout problem
You need to expand your annotations menu all the way to find the fractions menu.
NX 9.0.2.5 / PDW
Win 7 Pro x64
the command finder is the binoculars icon on your toolbarhttp://www.eng-tips.com/
It seems to be something with the hole callout dimensioning
If its a "thread feature", then it works fine, when its a "symbolic thread" then it gives me the line between the upper and lower---now in the case of 10-24 unc, it puts a line under the entire text, nothing underneath
If I go into settings and uncheck the callout so it puts nothing there, the stub portion of the leader is correct, if I turn on length only it puts the line back
NX 9.0.2.5 / PDW
Win 7 Pro x64
wierd
NX 9.0.2.5 / PDW
Win 7 Pro x64
Maybe look at this link and see if there is something that will help you
http://community.plm.automation.siemens.com/t5/NX-...
Insert -> Dimensions -> Feature Parameters...
...function still exists, the preferred approach is to now use the new 'Hole Callout' method option found on the Radial Dimension dialog.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
